So i have this problem with PE/BE not coming in like it should at most times it will activate but just not add fuel to reach target 11.5 WOT you can clearly see it activate wile monitoring fuel system status and AFR commanded randomly at times it will work wright and start 13.0 then drop to 11.5 and hold then other times it starts 13.0 then clime to 17.0 at that time I'll pull out of TPS or at times it just chokes out I have tried many different options with PE & BE with ramp in throttle command KPA.. even putting PE supper rich and still random results or making BE supper rich same thing hopefully someone can point me in the right direction this is a OS 2-Bar tune.. Note I had the same problem before OS 2-Bar I actually thought going OS 2-Bar would help??
2005 Gto Torid Red
408 Stroker 10.3 Cr
Howard Cam
0.625 Int & Exh 284 Int 301.6 Exh 118 Sep
823 Squire port heads built but not ported
Snakeaters 80-lb injectors
Magnuson 2.3 Od cog pulleys 3.0 Front
Innovative West 10% Od 8-rib conversion
