Results 1 to 14 of 14
Thread: Truck barely pulls....possibly pulling timing
    Jun 2021
    4
    Hey all,
    I'm new to HP Tuners as well as tuning but i have a 2010 GMC Denali with a 6.2L completely stock that pulls off really slow unless I hammer it. The check engine light is on with a few codes related to Evap and one knock sensor code. I changed out the knock sensors (still has the code even after clearing) but I scanned it and it looks to me like it's pulling timing when I pull off. I just need to know if I'm reading the spark correctly. I've attached the scan that shows where I think the timing is being pulled but I need someone who is more experienced in HP Tuners to take a look.21-06-04 13-57-03.hpl
    Senior Tuner Lakegoat's Avatar
    Jul 2012
    Florida
    1,459
    Yeah, you definitely have something going on with the spark. Post your tune
    2013 Silverado 5.3, 6L80k 8.8
    13,565
    Yeah, figure out that knock code still. Did you use a new OEM sensor?
    And if you are not running a E85 blend of fuel you need to disable that feature. The truck says you are running 22.7% alcohol content and that will screw up fueling if that is not what you are really running. The virtual flex fuel feature is not very good on those trucks.
    Jun 2021
    4
    Sorry it took so long but I set the Flex Fuel sensor to disabled and tried it but it did the same thing. I downloaded the tune which I'm attaching a long with a new scan file
    Mar 2011
    Ripley, MS
    1,865
    That P0606 is not a good code to see. It's a processor code. You'll likely have to replace the ECM.
    Jun 2021
    4
    Do you think that would be the reason it’s pulling timing?
    Mar 2011
    Ripley, MS
    1,865
    Quote Originally Posted by dcanzater View Post
    Do you think that would be the reason it?s pulling timing?
    It's possible. I've seen them act crazy when that code pops up. Try this as a test...
    I just disabled the knock sensors in your tune. Try it and see how it performs.
    I wouldn't recommend towing without them, but it'll certainly be fine for a test drive.
    Stock 2010 GMC Sierra Denali 1500 6.2L Tune Flex Fuel Disabled NO Knock Sensors.hpt
    405
    2,326
    FYI disabling KS codes does not disable their function.
    Mar 2011
    Ripley, MS
    1,865
    Quote Originally Posted by 2xLS1 View Post
    That is correct Sir. I didn't disable the codes...just the function.
    405
    2,326
    Quote Originally Posted by kevin87turbot View Post
    Why would you do that? Just disable the codes to kill the preemptive timing pull.
    Mar 2011
    Ripley, MS
    1,865
    It's not throwing the knock sensor codes in the last datalog, so disabling the KS codes wouldn't change anything. But, unfortunately, it is pulling a lot of timing still. It's also throwing a P0606...which is never a good sign.
    Jun 2021
    4
    I’ll try the tune in a few days, do you know if this truck has the same ECM as a 2010 Camaro SS? I have a spare ECM for the Camaro that I could swap in....
    Mar 2011
    Ripley, MS
    1,865
    It does have the same E38 ECM...but you won't be able to just flash it with HP Tuners and convert it to a Sierra ECM. If you have a friend at the dealership, they can help you out with that.
    7,640
    Quote Originally Posted by cantakowep View Post
    I don't own this car, but I can tell you about the tires on my truck.
    Cool! I am anxiously awaiting your edit 3 days from now where you add the spam links.
