Results 1 to 6 of 6
Thread: 2016 Corvette Z06 poor drive ability ( cam headers, 2300)
    Hello guys. I had a lifter noise on my car so I installed camshaft, lifters, on my Magnuson 2300 C7.
    I could not get in touch with Crawford for some reason and the tuner I used basically said hes done tuning and the drive ability is a trade off.
    Can someone guide me the right direction on what I need to change? I know how to scale the MAF but thats about it and it looks fine.
    The car is just not smooth at low speed cruising.
    Thanks, James
    [email protected]
    Senior Tuner Lakegoat's Avatar
    Jul 2012
    Florida
    1,459
    What kind of map sensor do you have with a linear of 425? Looks like your map reading at key on, engine off is around 89 to 90kpa. What is the altitude there?
    2013 Silverado 5.3, 6L80k 8.8
    Nov 2009
    All Around
    3,149
    you can get in touch with me contact below for support
    Im at 3,500 feet elevation. The MAP is the stock LT4 sensor.
    Jul 2012
    Florida
    1,459
    I believe that the sensor config for that one should be NA-TIAP---if that makes a difference.
    Quote Originally Posted by Lakegoat View Post
    I just compared it to my stock sensor and it matches the same.
    Thank you for the suggestion though!
