I keep having an issue where my MAF errors out. It pulls a P101 - A ciruit range/performance issue.
I have tried:
Replaced the MAF with a new one
Relocating the wires, they went passed the alternator
I checked the signal wire itself which had 5 ohms on it, so i by passed it with a fresh wire
I have adjusted the calibration of the MAF in both the high and low, but went back to stock as it made no difference
adjusted the delta max air to 1.5x stock
adjusted the airflow max vs rpm 1.5x stock
ran it with out the airfilter, as its running the a patrol snorkel which does not breathe well
ive been logging the frequency, the maf state and airflow to confirm when its happening
I will try that, the reason we are trying to fix the error is to have it running right before we pop a turbo on it. Its only a little turbo but still dont want uncle rodney departing the building. I also read else where that sometimes its the throttle body that causes the error. AKA its open further than it says it is and that throws the error because now the measured amount of air doesnt add up. I will try swapping the TB and see what happens
