Can some check my injector data
Just would like someone to check that i inputted injector data correctly
I left the high flow rate at 30 only because of some posts i read, is this correct?
2003 ford mustang gt , 4.6l, vortech v1 charger, 47lbs ford performance injectors, bbk throttle body, sct 90mm maf, 340 lh fuel pump @ 40psi, 5 speed manual trans.
any other thought on tune are always welcome
what did your scaling percentage come out to and what all did you apply that to?
im still learning, im not sure what scaling needs done. could you explain
simple google search gives you all you need to know
http://www.efidynotuning.com/fuel.htm
