Originally Posted by
FSAE_Junkie
Lots of good comments here. I will say that I think there are at least 2 distinct issues at play here.
1) A 402 with 12 psi should be making more power than I am. Probably closer to 700 instead of 550 I would think.
2) An F1A at 70k RPM’s should be making more than 12 psi on a ~400 rwhp NA engine.
I’m choosing to look at #2 first, because that seems easier to hopefully diagnose.
I did discover 2 sizeable boost leaks. The first was a 5/16” port on the side of the LS2 manifold that I had capped off a long time ago, but the cap had dry rotted substantially and was now a full ?” dia leak. At 12 psi, this would flow about 1.5 lbm/min. Unfortunately, this probably isn’t worth more than about 0.5 psi. After fixing that, I still couldn’t build pressure in the intake tract with my air compressor; The red Procharger race valve was leaking substantially onto my foot. The valve is 11 years old at this point, so I figured I would go ahead and get a rebuild kit since they are pretty cheap. On disassembly, I didn’t see any reason it should have really been leaking other than maybe the Teflon seal being worn, but after putting it back together, it sealed better enough that I could at least get to 10 psi. I’m hopeful that it had some role to play in the low boost or maybe even the erratic boost.
I’m still not 100% ruling out belt slip, but I’m not sure how conclusively verify without building a tach setup so that I can read the procharger pulley RPM. Realizm, that is good to hear about the Gates RPM belt, I’m skeptical how well these Gates green belts can hold given that they are so stretchy. I do have an RPM belt I haven’t installed yet, but it’s for a larger crank pulley (7.65 vs. 7.0) that I’m waiting to install. I didn’t want to confound things too much with more impeller speed as of yet. I guess I could just buy an RPM belt for my current pulley combination, but was sort of hoping avoiding spending another $70 on a belt for this interim setup.
Realizm, I'm looking through your log and I think there's some things to be gleaned from this. I'll have to make another post covering some of the comparisons. But yes, certainly if you could a 3rd gear pull all the way up, that would be even more interesting to look at. I assume your log above is from 2nd gear?
