Hey Guys.
I am new to the Forum so it might be that i ask well known questions but i couldn't find the answers in the history.
We put a 2007 8.1 workhorse with 6 speed Allison in my 1982 Airstream.
It runs okay but there are things i want to change but things don't response as expected.
is there a kinda course i can view?
some examples.
the timing table that i alter, low and high octane are filled in with values that seems a good start to me based on expereince, but when i log it there are values that are nowhere in the map.
full throttle at 1800 rpm it goes back to 17 degrees or less while the map is at 24 or higher.
i tried to tae off all restrictions and it runs on octane 95 or Lpg which is 105 or higher.
i do have a malfunction on the nocsensor frequenty, probably cause i had te relocate it but i put everything to zero.
So it is unclear to me why it responses so very different than the map, also atfull throttle 3500 rpm it suddenly goes up to 39 degrees while the map is filled in at 30 ish
second is that the fuel table is not as i am used to
i see lambda values but they must be calculated since a smallband can never meassure richer areas.
As far as i can see there are no injection time maps
i would like it closed loop up to 50% throttle and richer open loop above that but no decent result yet
further is there the allison, it shifts up at 2100 rpm with low throttle but that can be 1500 rpm for me, or related speed.
i tried to chnge it in the gears but that didnt go well, it started reving up between gears
I normally do stand alone ecu's and now the basics when it is in normal language to me but this is 1 i would love to learn.
don't mind paying for a good explanation,i accepted that trial and error doesn't bring me where i want to be.
thans in advance, Grts Buddy
