Results 1 to 5 of 5
Thread: USB plug only connects power when partially inserted, not fully inserted.
    Jun 2021
    2
    Question USB plug only connects power when partially inserted, not fully inserted.
    Having this weird problem, if I fully seat the USB plug into my laptop the power light goes off and it acts like there's no connection. If I slowly pull it out and have it partially plugged in, I get connection. If I wiggle or even slightly move it at all, it disconnects again. This seems like a nightmare situation to have if I'm writing a new tune to the PCM and the cord moves and bricks everything. Not really sure what to do here. I was able to read out the stock file without moving anything but I'm not at all confident in writing to it.
    Video of it here.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,261
    have you tried a new usb cable? If not start there. Also try an alternate usb port on your laptop.
    Jun 2021
    2
    Imagine that, I tried my Samsung phone's cable and it worked right away zero issues. You may want to let your cable supplier on the MPVI2 know. I haven't tried transferring data on it but it shouldn't be a issue since it's for a phone that does data transfers?.. Thanks!
    Here it is working...
    HP Tuners Support
    (foff667)
    28,261
    Quote Originally Posted by okbutwhytho View Post
    If its a new MPVI2 I would suggest opening a support ticket, I was under the assumption that the interface was not new and you've been able to successfully use it in the past without issue.
    Advanced Tuner outlaw_50's Avatar
    Nov 2020
    United Arab Emirates, AlAin
    204
    Thats because you are using usb 3.0 cable on a usb 2.0 port (on your laptop)
    just use another cable
