Results 1 to 17 of 17
Thread: 4.6L 3v Swap - Return Style Fuel System - doesn't run
    Jun 2021
    7
    Hey guys, new to tuning here so please bear with me haha. I've got an F100 that I have swapped a 4.6L 3V into, from a 2006 mustang. The motor is all stock even using the factory airbox. The only thing I have changed is set it up with a return style mechanical fuel pressure regulator and stripped down the wiring harness. EVAP has also been removed. The issue I am having is that the engine will sometimes fire and run for a second or two, then die. Other times it will not fire at all.
    I did get the donor car complete and the motor ran great before removing it from the mustang
    As far as the tune, I have disabled PATS, disabled EVAP, turned off the rear O2?s and tried to set the fuel settings for return style. It seems like a fuel issue, so I probably did something wrong here: Aeromotive Fuel pressure regulator is set to 40 PSI.
    Desired Voltage set to 15 across the board (I am using the power output from the FPCM only to control the fuel pump relay) - Note: I also tried just powering the fuel pump relay from the ignition, with no change to the starting/running conditions
    -Note: fuel pump comes on with key and stays on (never shuts off) ? this should shut off after a few seconds right?
    P, I, D, all set to zero
    Should I turn off adaptive voltage?
    Should I set it to fixed duty cycle?
    It seems like its getting way too much fuel. I have attached a log of trying to start the truck. Just trying to figure out if this is a tune issue, or a wiring issue....
    F100 Start Attempt 2.hpl
    Jun 2021
    7
    4.6L 3V for F100.hpt
    Here is my tune as well
    Mar 2019
    351
    What your describing sounds like a mass air meter issue. Is it using the stock MAF in stock location?
    Jun 2021
    7
    Yeah MAF and air box/filter are all stock. Unplugging the MAF doesn't change the symptoms....neither does unplugging the FRP, cam sensors, etc... I spent some time tonight with my multimeter, and I have 10 volts in my VREF circuit at the fuel rail pressure sensor. Also found a couple others online with very similar issues, and it turned out to be a bad PCM. Could this be likely? It was running in the donor car two moths ago. Maybe I somehow damaged it?
    Mar 2019
    351
    It is possible, but seems unlikely. Verify all of your ground locations are solid and direct to metal with no paint or rust in the way. Also make sure nothing in the harness got pinched or cut.
    Jun 2021
    7
    I double/tripple checked all of my grounds and sanded all the terminals tonight... no change. I can't find any pinched or damaged areas in the harness. And I can't seem to repeat the 10 volts in the FRP VREF circuit, now it is reading 5.05 volts, as are each of the other VREF circuits. I did try un plugging both cam position sensors at once, and that will make it run for a few more seconds, and fire up more consistently. it also has an audible misfire with both sensors unplugged.
    Jun 2021
    7
    Any other thoughts on things to test, log etc... I'm running out of ideas haha. I'll play with it some more this weekend, but I think next week I'll send my PCM out to get tested. Anybody ever deal with SIA electronics? Their test/repair process seems pretty reasonable. Send them the PCM, they test it, if it is all good they will charge me $90 and they'll send it back and I can rule that out... If it's bad and unrepairable they only charge for shipping, and if they can repair it the price starts at $169.
    Mar 2019
    351
    Its worth a shot.
    Jun 2021
    7
    So I ended up installing the factory mustang pump in the truck and set it back up as a returnless system. So now the fuel system is back to stock form using the fpdm. and I also tried another PCM, and ran all of my grounds directly to the negative post on the battery. None of these changed the symptoms
    Has anybody on here successfully swapped a 3v into something else using the stock PCM/Harness? I am at a loss of what to try next. I have come across a couple of other thread on different forums of people with the exact same issues, none of which have been able to get it running. Could there be something in the cluster/BCM/PATS/other modules that the PCM needs to see?
    After doing some more research, unplugging both cam sensors puts it into some sort of "failure" mode and will then fire the injectors and spark on both cycles, thus why it will run for a couple seconds but has a bit of a misfire. Also to note, with the cam sensors unplugged, I can press the gas pedal and get a response (engine revs like it should). It still shuts off after about three seconds though.
    with the cam sensors plugged in, it will only run for about a half second, and has no response to the throttle pedal.
    Mar 2010
    New Orleans, LA
    630
    Ive done several thousand of them never an issue
    logging would show you exactly whats going on
    sounds like you have a custom maf and dont even know it
    Jun 2021
    7
    would you mind taking a look and see if anything stands out?
    F100 Start and rev - cam sensors unplugged.hplF100 Start attempt cam sensors plugged in.hpl
    The tuning/logging is new to me so if there are other things I should be logging, please let me know.
    Also, the MAF is the factory Motorcraft MAF.
    Mar 2010
    New Orleans, LA
    630
    I dont use hp but it should be obvious. Look at the maf counts and see what you have.
    Is it in the factory maf housing ?
    Mar 2020
    21
    Quote Originally Posted by decipha View Post
    What do you use? Do you run factory harnesses?
    Mar 2020
    21
    Did you figure it out yet?
    D
    I did a 3V swap into a 67 Mustang , fit the factory fuel pump in the tank, keeped the returnless but on the fuel pump you need to block the syphon that feed the right side in the S197 tank .
    one thing I had to deal is if you splice the tps wire signal for a transmission stand alone or anything else , it will fail start and no throttle .
    Mar 2020
    21
    Quote Originally Posted by Alex5.0 View Post
    That raises another question. Could you run a return style set up with an aftermarket pump that is PWM and use the factory adaptive voltage setting? Or would you have to block off the return style line back? I can't see why you couldn't.
    D
    Quote Originally Posted by Dman64 View Post
    D
    Yes I did , you have to find the output on the fpdm that control the pump with the fuel prime , there is 2 or 3 ignition positive on the fpdm , dont remember which. You still have to change the returnless parameter , fpvt , PID ... etc but you dont turn of the switch for the fuel pump. That way you can keep your fuel rail pressure sensor and have a prime Key ON and pump will not run continiously .
