The option to add the Delivered Engine Torque channel is missing on my scanner. I tried reloading the program and using the beta but I still don't have it as an option any suggestions on how to fix this issue?
If you had it previously; in one of the scanner menus you can select to re poll the channels your car has. Try that. If no luck then you'll have to go the support road.
Thank you I'll try that.
