VCM Scanner Channel Config setup for MK5 Golf GTI
So I've recently finished building my MK5 GTI engine and trans and am finally at the point of tuning. So I've had about 4 years of experience with tuning on standalones an this is my first time with something like HP.
I connected the scanner and loaded up the default Channels and unfortunately it only loaded up 3, throttle pos, rpm and speed. I have configured my own parameters as desired however they all come up as
An unsupported parameter. is there any direct post on how to correctly set up the ECU to show all parameters or have i just done something wrong?
I have attempted to follow http://www.hptuners.com/help/vcm-sca...hitecture.html to ensure I'm doing everything correctly.
Steps taken are as followed.
1. setup VCM suite
2. connected to the car and made sure everything was up to date.
3. loaded vehicles defaults
at this point all that came up was as follows
1. Engine RPM (came up at 5200 where actual RPM was around 500)
Vehicle Speed, read above 180 at standstill
accelerator pedal position also not accurate or true
what have I done wrong and how do I correct my errors.
please feel free to link me to the required forums and information. I have done some searching and unfortunately I'm not having much luck.
thank you in advance!
