Results 1 to 7 of 7
Thread: Thermostat
    Potential Tuner Drogemeister's Avatar
    Mar 2021
    Pahrump, NV
    9
    Thermostat
    I have a factory thermostat, which I believe is 203 degrees. I am going to get the 180 thermostat, but in the meantime, what it cause harm to lower the fans 20 degrees or is it recommended to wait until I get the cooler thermostat?
    dont lower fan time before install the 180 or any other because fans will open early while the thermo is not in timing with it
    Jan 2021
    Cape Town
    84
    I found that 180 may be a bit cool. It seems the 5.7 hemi is more happy with a 190 thermostat.
    I agree with GeForce, fist fit new thermostat and only then change the fan activation temps.
    2010 Jeep GC 5.7 Eagle Head motor, 2" OME lift, cats removed, full MDS delete
    Nov 2017
    816
    Turn off P0125 & P0128 before you install it. These permanent codes are a bitch to get cleared.
    If in doubt, multiply everything by 1.1.
    Advanced Tuner f.creek-ranch's Avatar
    May 2018
    Germany
    586
    watch the oil temp.
    Jun 2021
    WV
    41
    Does anybody have thermostat issues? I use a 180 with my Kenne Bell and the thermostat just died at 10k miles and caused an overheating issue. This isn't the first issue I've had with thermostats. My Ram and Charger both have had thermostat issues. Does anybody know of a decent thermostat for our cars?
    May 2018
    Germany
    586
    Use Mishimoto and bigger radiators. Big oil cooler for lower temps.
