Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Needs some help reading log from my new 4XX stoker build
    Advanced Tuner coanan's Avatar
    Mar 2009
    S. Florida
    582
    New build, just starting, fourth tune mod to get it this far.
    Starts, idles, revs, but coming down just dies
    My Whipple didn't show up, so I was forced to reinstall the E-force until then.
    Link to build.
    https://www.lxforums.com/board/engin...o-carnage.html
    2018 Trackhawk PCM/TCM tune by Dusterhoff.
    Flex Fuel, MMX faux 95mm TB, GripTec 2.85, 10% ATI lower, FIC1200, ARH 1 7/8 w/cats, 180 T-stat
    13 Chrysler 300S, RAM BGE 412 stroker, cam motion 232/246 619/619 118 +4, ATI 18% OD pulley
    Whipple Gen5 3.0, 2.50 upper pulley, Smooth Boost controller, FIC 1200 inj. Nick W 108mm TB, FORE dual return fuel system, E85, FTI 2800 stall(SRT83380), SHR WAR Viking trans and valve body, Getrag 3.73, 1 7/8 kooks w/hi-flow cats, 3" Magnaflow Cat-back 943rwhp
    Advanced Tuner PurpleRam's Avatar
    Aug 2017
    Quakertown PA
    478
    I have a few tunes from a couple bigCI big Whipple builds , ones a 441 with a 4.5l the other is a 454 with 4.5 both of those are trucks both 14s they should be close, the 463 with a Kenn Bell is a challenger.. eventfully we had to go Haltech with that one the OEM ECU couldn't deal with the 7500+RPMs and it would never idle ...... the only Eforce I've been involved with was 431 in a 12 challenger ,1st cam was close to yours 230/245 620/635 120 ,but had a TH400 behind it so no tranny stuff to worry about..I'll compare and see if I find anything
    04 GTX........ 8.91@151mph 392Ci G3Hemi NA 3600lbs 2.6HP/CI Naturally Aspirated
    05 GTxtreme 9:45@142mph 426Ci G3Hemi NA 4000lbs
    G3 Hemi Videos
    https://www.youtube.com/channel/UClS...5mXdDR5sOxs10Q
    Mar 2009
    S. Florida
    582
    [QUOTE=PurpleRam;653830]I have a few tunes from a couple bigCI big Whipple builds , ones a 441 with a 4.5l the other is a 454 with 4.5 both of those are trucks both 14s they should be close, the 463 with a Kenn Bell is a challenger.. eventfully we had to go Haltech with that one the OEM ECU couldn't deal with the 7500+RPMs and it would never idle ...... the only Eforce I've been involved with was 431 in a 12 challenger ,1st cam was close to yours 230/245 620/635 120 ,but had a TH400 behind it so no tranny stuff to worry about..I'll compare and see if I find anything[/QUOT
    Thank you.
    Waiting on the Gen 5 3.0 Whipple now, ordered nearly two months ago.
    E-Force to break-in engine then off when Whipple arrives.
    ID1050X and MMX 95mm TB with Whipple.
    Mar 2009
    S. Florida
    582
    So this is officially above my paygrade. I was able to fake my way through the other builds, but not this one.
    Need someone in the S. E. Florida area to sit behind the wheel and tune. Where the car sits is not close to where I live. I can't wait hrs or days for tune revisions.
    Maybe that I'm trying to tune NN and this combo is not having it. Most likely.
    It starts like I have 13.1 CR, idles for a while, then goes into surge, then stabilizes for a while, then goes into surge. Repeat and rinse.
    I'll include log from laptop. Not sure why log in last reply doesn't look like log on laptop.
    Apr 2011
    42
    Fuelling looks a fair way off +-10% everywhere.
    Id personally go to VE and do away with NN at this point.
    When NN is on it uses lots of airflow model stuff we cant see. When you switch NN off the idle becomes much easier
    Mar 2009
    S. Florida
    582
    Quote Originally Posted by L4staero View Post
    Sound advice. I'll give it a try. Won't see car till Monday.
    Mar 2009
    S. Florida
    582
    Turned NN off. Think tune is so butchered now nothing is going to fix it.
    I officially don't know what I'm doing and seeking a good tuner in S. Florida
    Apr 2011
    42
    Turn NN off, put injector data back to how the INJ manufacturer suggests and tweak the VE table to suit.
    Even do the above and upload new tune and log and we can help tweak
    Mar 2009
    S. Florida
    582
    OK, thank you. Be Thursday before I get to car.
    Inj. are from a Whipple 2.9 kit.
    Mar 2009
    S. Florida
    582
    Quote Originally Posted by coanan View Post
    OK. some short logs, couple long. it starts to die and sits there with a couple pops out TB then recovers.
    Fueling or Air flow??
    Mar 2009
    S. Florida
    582
    Latest, not the greatest
    Mar 2009
    S. Florida
    582
    Finally, In contacted with a tuner in S. Florida.
    Should be good to go. Sent him tune and log.
    He may just scrap it when he sees it.
    Apr 2011
    42
    Ive tweaked the VE in the low load areas. DO NOT enter WOT yet
    Mar 2009
    S. Florida
    582
    Thank you. I'll give it a try tomorrow.
    Mar 2009
    S. Florida
    582
    Wouldn't come up to idle 0050, just popping through TB. Shut it down.
    I did some changes to a another tune.
    Turned off exh cam phaser, made idle more stable.
    Turn A/C on it's stable, put in gear and it's like turning ign. off with a pop through TB.
    A little RPM and it will go into gear with a little surge and stabilize.
    Been all over airflow and fuel, idle torque stuff. I'm missing something and don't know what.
    Still waiting on tuner here to get back to me, he is busy.
    Apr 2011
    42
    The fuelling is way off, you will just need to keep adjusting the VE table to dial it in
    Did you reset adaptives and do a throttle relearn after flashing the calibration in?
    Mar 2009
    S. Florida
    582
    Thanks. Yes on adaptives before each start. Didn't do a throttle relearn.
    Is there more that fueling I'm not seeing when it just dies going into gear? Idle torque throttle or timing.
    A little throttle power break and it will go into gear and not die.
    Mar 2009
    S. Florida
    582
    Reading log and knowing where to go into tune to fix it is way beyond my comprehension.
    Mar 2009
    S. Florida
    582
    Thanks everyone for the help and support. Ya
    At least someone on YT was willing to share their knowledge, something I thought this forum was for.
    Was pointed to an area that I was over looking, after some tweaking no surging at idle or dying in and out of gear.
    Was able to get out on road for some VE logging and tuning.
    That's good news! Are you going to share what the fix was?
