have a vortec 5300 in 68 camaro with walbro gss340 pump in a fuel sump pan with return-style pressure regulator set to 50psi
old pump sometimes made lower pitched humming sound
noticed the sound changed when i had the turn signals on. there was no fuel pump relay installed. doh!
installed relay & replaced pump assuming humming sound was due to lack of power & pump may now be damaged
now the new pump has a higher pitch whine, audio-clip @ https://ls1tech.com/forums/attachmen...-fuel-pump.wav
there is plenty of power to the pump now as both relay & battery are in the trunk above the fuel tank
what would cause this noise from the pump ? could the sound be due to a vibration in the sump ?
many thanks for any input offered
