Results 1 to 4 of 4
Thread: 4l60 in ls swap unusual shifting problems
    Aug 2014
    5
    So, I just got my 1982 Chevy K10 started today, and went for a drive. however, when i shifted the transmission to Drive(overdrive) the trans does nothing, it does not attempt to move the truck. same for 3rd gear. however, if i place the transmission in 1st or second, the truck drives fine. Here is where things get odd. Once i get moving, i can shift into overdrive, and the transmission will automatically shift through all gears as they should. However, if i shift out of overdrive, ( into neutral/reverse/park) i then have to shift back into first, take off, and shift up into overdrive. I was hoping someone had seen this or had any ideas as to what the cause could be. I have attached the current tune in the truck.
    Mar 2011
    Ripley, MS
    1,865
    That's typically a problem with the transmission sprag assembly. Unfortunately, I've experienced the same issue myself.
    Aug 2014
    5
    even if once i do get it into drive it acts normally?
    Apr 2022
    17
    shift lock is enabled in the tune that would make it act funky! its a year old but just seeing your post.
