Results 1 to 7 of 7
Thread: Ford Mustang GT 2007 Supercharger MAF tuning - lean WOT
    Aug 2020
    2
    HI,
    I have a problem with car running lean at WOT. Wideband shows (not connected to MPVI) 14,7 at 2500-3500 rpm going to 12,7 at 5000 rpm and than going up to 14.0 at redline.
    I have tried many different settings but can't make the engine run at desired lambda at WOT.
    It has 41lb injectors.
    No matter what MAF/voltage settings, no matter what fuel pressure it is running at load it goes lean.
    What I have notice on the log (attached) is that MAF (g/s) goes from 634 to 0 and again up. MAF volts are rising normally.
    I have attached current tune and log file.
    I can change MAF scaling at 3.0V to 5.0V by +/- 20% and it doesn't do any difference.
    Injectors PW is always aprox 12 ms at high load.
    Not sure where I should look for the settings to change the fueling at high load?
    drive test 5.hpl
    Ford Mustagn Superchareger v12.hpt
    Mar 2019
    351
    Plot your fuel pressure and make sure its doing what it is supposed to. You could have a fuel pump issue, this has to be right before moving forward.
    Use these channels, try not to clutter it with a bunch of other stuff:
    Engine RPM
    Air Load
    Throttle Desired Angle
    Short Term Fuel Trim Bank 1 (SAE)
    Short Term Fuel Trim Bank 2 (SAE)
    ETC Throttle Angle Error
    Engine Coolant Temp
    Intake Air Temp
    Throttle Angle
    Timing Advance
    MPVI2.1 -> Ballenger - AFR500
    Accelerator Pedal Position
    IPC Wheel Torque Error
    ETC Torque Request
    Long Term Fuel Trim Bank 1
    Long Term Fuel Trim Bank 2
    Calculated Manifold Absolute Pressure
    Mass Airflow Sensor
    Control Module Voltage
    Engine Brake Torque
    Absolute Load (SAE)
    Throttle Position (SAE)
    Run another log and post.
    You need your Wideband input into the MVPI. You have no way to input what you are seeing into your logs.
    Aug 2020
    2
    HI,
    Thanks replay,
    Fuel pressure is spot on with the target. 264 kpa on idle rising to 384 kpa at high load. (it is logged channel)
    Unfortunately I don't have a cable to connect wideband to MPVi but external LM2.
    I did some test with +/- 25% on the MAF sensor scaling and it didn't change anything so it must be some other issue with the calibration.
    Is it only MAF vs Voltage that changes fueling at high load or is there any other map that can be adjusted?
    Mar 2019
    351
    Plot LTFT+STFT (math) as a percent. In the column plot RPM, on the row axis plot TPS as a percent. Match these values to the charts for load with failed MAF in your tune. That is the main governor for transitional and high load fueling.
    Your mass air meter should be LTFT+STFT (math) against mass air volts.
    Advanced Tuner f.creek-ranch's Avatar
    May 2018
    Germany
    586
    set max aircharge load to 1,5.
    Im a little confused.
    Your fuel trims shows your not in open loop.
    Check your vacuum, maybe theres a leak.
    Are the settings for your injectors OK?
    What charger do you got?
    Feb 2017
    TX
    761
    Set open loop delay max to .1.
    There are other ways to adjust fuel but none that would prevent PE.
    Oct 2018
    5
    i've seen something like this once that sounds like youre describing, after a lot of trial and error it turned out to be a torque error issue, i played around with the driver demand and maxed out some of the torque tables to get around it. the give away was that i logged throttle position and saw that when the car was going lean the throttle was closing down below the WOT threshold and going out of PE (even though the accelerator was buried to the floor). it's a long shot but maybe this is what's going on with your setup.
    cheers,
    -Nick
