Originally Posted by
kevin87turbot
I don't doubt that it doesn't show knock until 30 degrees, but I typically see the power fall off around 28 degrees on the L76/L96 and LS3 combos with stock compression like yours.
On my old V-max truck, I had the same combo as yours, but a little larger Comp Cams camshaft. I ended up with 23.5 degrees timing at peak torque (around 4800 rpm) and around 25.5 degrees timing at 6000 rpm. It made the same peak power from 26-27 degrees at peak hp. It would start losing power at 28 degrees and lost even more at 29 degrees (lost around 6 hp at 29 degrees.) I never tried 30 degrees with it. It was on 93 octane only.
On my Pontiac G8, it would actually make peak power at 27 degrees. It made nearly the same at 28 degrees. (within 1 hp). It would fall off 4-5 hp at 29 degrees.
I'm not saying you're wrong, but I've dyno tuned 41 rectangular headed combos on the last couple years, and they nearly always make peak power on 93 octane from 25-27 degrees. The only exception that I can recall are a couple of lower compression combos that I tuned. They seems to like a couple extra degrees. It may not be the case with yours, but I just want you to keep it safe, and not give up any hp with your tune. If it does detonate at all, you'll always see it puff smoke...
If it's a transient fueling issue, you'll see a little rich spike on your wideband. I didn't notice that on your datalog.
I suppose that you might have one or two injectors that flow more than the rest. I've caught that issue on the injector flow bench a couple times. If this is the case, it will show up on your plugs as well.
On an unrelated topic, does your transmission shift really hard? I just saw that you're tuning in SD mode, but didn't delete the Trans Diag codes...that typically results in max transmission line pressure.
