2015 Silverado Truck Random Misfire + Significant Loss of Power!
So I've been trying to figure out what the issue is with this truck but unfortunately I could not!
Here's a brief:
Truck runs and drives great however when I floor it, it flashes the CEL.
Things that was changed to it are as follows:
Spark plugs and wires replaced Intake manifold & TB have been cleaned Fresh oil Checked and inspected valve springs
Please notice the MAF (g/s) it reads low as well as the torque.
I am attaching the tune + bunch of logs
Appreciate your help and thoughts guys!
Have you ran a compression test? Smoke check?
Ya, find which cylinder is misfiring and do the basics to make sure you are ok mechanically.
Thanks guys!
No compression test so far and all spark plugs and wires have been replaced.
as per the log it says 3 & 5 but they do seem fine
Potential lifter failure, though the cylinders you're seeing misfires on aren't DOD cylinders.
I just recently had one lifter in cylinder 7 (DOD) and one lifter in cylinder 5 (non-DOD) fail almost concurrently. Two bent pushrods and a scored cam lobe later, I'm now DOD-delete and am never looking back.
