ok so i am in the process to find out if my EGR is turned off from a tunner at nizpro when my ranger got tuned for the 3inch exhaust....they said they turned it off but when i put the block off plate car ran shit and back fired..also when i went back and told them what happen they said you cant close the EGR because my car needs the EGR to build boost
what a bunch of Balonneyyy.....
i guess its up to me to turn off my EGR tables.
so on almost all my EGR base tables i see this ? i remember VFL77 telling me to bump the numbers Very high to a number the engine will never see at low loads so the EGR never opens. here is that table
Attachment 118530
and in engine Diagnostics it looks like everything is disabled ??
Attachment 118531
also here is my VCM scanner reporting that it isnt opening ? is it safe to say EGR is closed ? but if so why is my ranger Very low on power with block off plate installed and back firing ?
Attachment 118532
