On a 2012 Challenger,how do I change the tune for 3.73 rear gears ? I can't find the pinion or tire size settings in editor.
This person somehow was able to,but probably an older car ?
2018 Trackhawk PCM/TCM tune by Dusterhoff.
Flex Fuel, MMX faux 95mm TB, GripTec 2.85, 10% ATI lower, FIC1200, ARH 1 7/8 w/cats, 180 T-stat
13 Chrysler 300S, RAM BGE 412 stroker, cam motion 232/246 619/619 118 +4, ATI 18% OD pulley
Whipple Gen5 3.0, 2.50 upper pulley, Smooth Boost controller, FIC 1200 inj. Nick W 108mm TB, FORE dual return fuel system, E85, FTI 2800 stall(SRT83380), SHR WAR Viking trans and valve body, Getrag 3.73, 1 7/8 kooks w/hi-flow cats, 3" Magnaflow Cat-back 943rwhp
Ok,thanks I will check the scanner options. I have the latest beta hptuners. What is Acc/FCW ?
Ok,thanks, I'm not worried about that.
Thanks,Coanan. I got the gear ratio,and tire size corrected.
