Results 1 to 8 of 8
Thread: Nag1 with 3.73 rear gears
    Myerstown ,PA
    26
    On a 2012 Challenger,how do I change the tune for 3.73 rear gears ? I can't find the pinion or tire size settings in editor.
    Myerstown ,PA
    26
    This person somehow was able to,but probably an older car ?
    Mar 2009
    S. Florida
    582
    Quote Originally Posted by chevy 6.0 View Post
    I take it you have HPtuners. Scanner - special functions - input gear and tire size.
    If you have ACC/FCW it might not work anymore, at least mine doesn't.
    Myerstown ,PA
    26
    Ok,thanks I will check the scanner options. I have the latest beta hptuners. What is Acc/FCW ?
    Mar 2009
    S. Florida
    582
    active cruise control - forward collision warning
    Myerstown ,PA
    26
    Ok,thanks, I'm not worried about that.
    Myerstown ,PA
    26
    Thanks,Coanan. I got the gear ratio,and tire size corrected.
