Results 1 to 9 of 9
Thread: AEM 30-0334 OBD2 Wideband PID for dash logic?
    Jul 2019
    14
    I just purchased a Dash Control dashlogic for my C6 vette to display my AFR ratios on the HUD. I have an AEM 30-0334 OBD2 Wideband and figured it would have no issue displaying this value since HP tuners picks it up. I have done some research and haven't figured out how to get it to work. Does anyone know what PID the wideband would be? Or has anyone ran this same setup and got it to work?
    Feb 2020
    4
    https://www.corvetteforum.com/forums...dashlogic.html
    My quick research and cross referenced their pin'ing shows this to be accurate.
    Results may vary but this will probably get you setup
    Dec 2005
    467
    The default PID is 0x24 (36)
    Jul 2019
    14
    Thanks! ^
    Reading over the documentation https://static.summitracing.com/glob...vm-30-0334.pdf PID 36 looks correct like you said.
    Just tried it in the DashLogic software and it seems to block out any PID number not registered in its table and wont work. Says PID 36 is invalid. Dang, so software is still a limitation.
    Dec 2005
    467
    I could make a patch with an alternate PID, for the 30-0334. But, if you are limited to what the DL device thinks goes with your ECU, it would, probably, conflict with something.
    Jul 2019
    14
    It seems like the PID lookup table is held on the device. I updated to a newer firmware I found on the corvette forums and after that it re-pulled all the PIDs from the device. Still no PID 36. But I am guessing a firmware is were the PIDs per module logic is and not the software.
    Jul 2019
    14
    I got excited for a second because I was able to get a preset for pid(36) by exporting a preset and editing the xml file and then reimporting it, it got passed the invalid pid that blocked it before. But when I plugged it into my car I still just get 0 for data.
    Also if I just select 36 in advanced mode on the HUD it just gives an N/A.
    So that's about all I can think of for now.
    Jul 2019
    14
    That link is for a different type of wideband. https://www.aemelectronics.com/produ...and-uego-obdii is the one I have and it uses the OBD2 to communicate over the can bus. I have sent an email to palmerproformance but heard nothing back. I am guessing there will be no support for this since he has since sold the dash logic to another company.
