Results 1 to 12 of 12
Thread: 00 start up idle issues
    Mar 2021
    17
    i got a p01 5.3 long tubes and a y pipe, no spring cam .500 .500 lobe separation of 112 , tbss intake and injectors 92mm throttle body. E fans So its like you have to help it get started and then it will idle as long as you let it. drive it and runs ok until you go to stop then itll act like its gonna die but wont it will turn 400 rpm but if you help it a lil bit then starts doing ok. ive about had it ill leave the tune and a log SOMEONE HELP A BROTHER OUT Please
    Oct 2019
    Canada
    33
    As a start increase the Base Running Airflow (Idle Airflow) across the board by about 1 g/s and be prepared to increase it more if required. Decrease idle timing (Idle spark advance) to the mid 20 degrees. At the moment you are commanding well over 30 degrees of timing at idle which is too much. Report results back here.
    Mar 2011
    Ripley, MS
    1,865
    Your coolant temp sensor isn't working. Once you fix that, it should start much better. It may be disconnected or the sensor could just be broken.
    Mar 2021
    17
    ABOUT THE COOLANT TEMP idk what is going on ive changed it twice and still not reading. i traced the wires back and nothing im at a lose on that
    Mar 2021
    17
    heres the changes except the coolant temp
    Mar 2021
    17
    it still needs help you can see in the log where i started it a couple times
    Aug 2009
    Calibrating
    3,373
    Going to foul the spark plugs with a -38 ECT temp that stays constant…
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    7,627
    Follow the diagnostics for P0118.
    Mar 2021
    17
    go ahead you have my attention...but seriously where do i need to start at and where do i go to follow up on this ..... cause im lost right now
    7,627
    First thing: Do you have the correct 2-pin connector going to the ECT, and not something else that looks similar and fits like the EVAP solenoid or brake fluid sensor?
    Unplug the ECT, then key-on. You should have ~5v at one pin and something like ground at the other pin. If you don't have those two as they should be, backprobe those pins directly at the PCM connectors, see if they are different than what you get at the other end.
    Monitor the ECT reading in the scanner and short the two ECT pins together. Does the reading change from the open circuit value of -38?
    Mar 2021
    17
    thanks ill try and trace that down in the am. im almost99% sure thats the right plug but ive been wrong before.
    Mar 2021
    17
    ended being the plug its self on the temp not working
