Results 1 to 5 of 5
Thread: Gen4 to gen3 5.3 in 2007 Silverado?
    Jun 2021
    Hello
    Was want to see can I put gen 3 5.3 in a 2007 Silverado that had a gen 4 5.3 with out having to swap reluctor?
    I want to use hptuner or some standalone to run motor and trans
    Thanks for the info and help
    7,619
    Nope. Sorry.
    Sep 2020
    6
    Why not. I was wondering the same thing as far as a quick and easy DOD delete?? I have a guy with a locked up 2009 that asked me this today. A fella couldnt put an 04 with the 04 PCM and Trans in an 09?? Or any pre AFM/DOD Ls for that matter??
    Chancellor B Rowland
    13,564
    Nothing in the 2009 truck would ever work again if you put a 2004 computer in it and all the engine wiring.
    You'd have no cluster, no ABS, no traction control, no proper body functions anymore because the 2007.5+ trucks all use can-bus.
    There is no converter box that allows for the 24x to 58x conversion. They only have a 58 to 24x.
    7,619
    In the beginner's mind there are many possibilities; in the expert's mind there are few.
