Results 1 to 8 of 8
Thread: P59 PCM Not Adding Timing For Flex Fuel
    I did not notice any timing advance with E67%. I thought I would have seen at least 5* additional. Any ideas why?
    Senior Tuner Frost's Avatar
    Jan 2006
    Richmond VA
    1,950
    I'd try a different OS. It looks right "on paper".
    Steve Williams
    TunedbyFrost.com
    Switched to 2006 Silverado OS and all is working as it should. Lucky I had the 06 Manual File to swap over as well
    Baltimore, Md
    1,204
    Quote Originally Posted by 30thta436 View Post
    I ran into this once as well. Post up the 06 auto and manual files you have that you switched to, I want to look through my stuff and figure out what it was
    9.0s in '09 @ 153 MPH
    Turbo 5.3 Volvo 740 Wagon
    May 2014
    USA
    444
    You need user defined parameters to define and set something reasonable in the "spark blend factor" table.
    Quote Originally Posted by aaronc7 View Post
    How would I define my own "spark blend factor"?
    Baltimore, Md
    1,204
    I think he means the spark blend table is not populated in that particular one where it has alcohol content on one axis 0% 25% 50% 75% 100% and you set blend factor (I make it 0.0 at 25% content so on small amounts it does nothing, .4 or so at 50%, and 1.0 at 75% up alcohol content so it does exactly whats shown in table and easy to check the math)
    Can you put up the original OS files you were using, and then the 06 Silverado OS and the manual OS files you combined to get it to work, and labled them with OS ID so people could ID their problems in the future with a search???
    May 2014
    USA
    444
    Correct, here is the spark blend table or whatever you want to call it. It will never add timing with E without reasonable values populated in this table:
