Originally Posted by
AdmiralSparklez
After a ton of reading and comparing, this actually doesn't seem that bad. Seems all I do with my mods is turn off O2s, change volume size for the manifold to 12.5, change IMRC sensor voltages to the correct voltages, and adjust the MAF for the intake. Seems like that's really it to get the car running.
Make sure you are choosing the correct stock file, I know sometimes it will save it as several ones. Had a customer with the same issue and it ended up being that he was choosing the wrong stock file. Just make sure it?s the one that has your vin number defined underneath and not just the basic stock file.
I am using an nGauge
