Originally Posted by
TriPinTaZ
I think your instincts led you in the right direction. 2.5 degrees of additional timing only gave 10more HP. That means there is a very small increase in power per degree past the 27 degrees on your 680rwhp run but a very large step towards danger. Ethanol and Meth will beat the bearings out of the crank before you see any signs of troubling knock retard. It's not like tuning on 93 pump gas. For the record, I typically run between 25-27 degrees by redline on the LT4's dependent on Ethanol content, Meth volume, and how much the blower is over spun. This would all be on stock cam stuff. For your setup, I just tuned a ZL1 with identical mods running E75 and Meth and I settled on 26.5 degrees of Peak Timing.
One suggestion I would give you is since you're spraying meth as a fuel source and your injector duty cycle is still below 5ms, get the SOI at 360 or below. There is no sense in spraying fuel at the very end of the exhaust stroke when you have plenty of room to start injecting at TDC. The exhaust valves are still closed at SOI 370 so its not a big deal. Also LAmbda of .78 is a bit rich for a DI motor. I am for .80-.82 on a setup like this.
