Results 1 to 2 of 2
Thread: Newbie with question about tune
    Jun 2021
    7
    So I just got my mpvi2 a couple of days ago. Got my wideband today, hoping to have it installed this weekend. My initial question is in regards to the tune as it is now. I purchased a long block to replace my old one that lost oil psi on the interstate. So I went from a stock 2002 5.3 truck motor to a 5.3 .030over, flat tops, 243 heads and a trick flow tfs-30602003 cam (.585 lift, 228/230 dur). Stock 02 intake, throttle body, 25.2lb injectors, maf sensor. This is in my 06 jeep wrangler. Had a local guy do a tune for the cam after i got it installed but its just not running as good as it should, I believe. If anyone has any thoughts on how the setup looks I'd appreciate any thoughts/feedback about which way to proceed. I won't have any running logs until my buddy comes in for the weekend to assist me with it. 3 weeks out from having my spine fused and can't do much solo yet. I apologize for the lack of info I can give you right now.
    Do I work with this tune or reload a stock one and adjust from there?
    Thanks for any help at all while i try to figure out what I'm doing
    Jun 2021
    7
    Went out to the garage and tried to get some more info. Not sure if its set up to record properly or all the pertinent info. Let me know what i need to change or fix please.
