Anyone have the data for this throttle body. Person insisted on using it because it?s ?pretty? even though I told him it?s more issues than it?s worth.
?Our greatest success comes from failure? -Confucius
IMHO
it will offer zero gains
Remote Tuning [email protected]
I 100% agree I kept telling him just polish the stock throttle but he?s not taking no for an answer. If you happen to know the values that would be great. Or PM me. I found some for the 85mm I?m sure it would run fine with that value but it wouldn?t be perfect.
That guy is posting bullshit files or something. I seen another thread his files aren't HPT and antivirus are showing threats.
Are you getting a lot of errors with the stock throttle body model? What gen are you working on? It's really not worth the work for no gains. Stock is perfectly good until it becomes a restriction, maybe at 1000HP.
It?s currently using the stock throttle body. It?s not on my car, it?s in someone?s im going to tune. I told him to keep the stock throttle body because it works the best. And his rational for wanting the bigger throttle body is because it?s pretty and looks better than the stock on on his Boss 302 manifold. I saw an old write up about doing a correction factor from txcharlie, where if you?re using the same style throttle you can do a correction factor aka 80/90 then raise it to the -1 to get the multiplier. I?m just not too keen on developing values to make it work when there?s already known data that works. If I was a parts developer or official tester that would be one thing. But I like to load values and be done.
Its very time consuming on both gens. I'd datalog the 90 on stock tb calibration to see where it's at. It's Very, very time consuming because each row is interpolated. A lot of people prefer and it is better to use a known calibration that has been flow tested but that data is not always available.
The relationship between the two tables is not inverse, there is no calculation for the tables either. The relationships are the columns to the axis. The axis is "assigned" to the cell values in the same column on the opposing table. You'll have to study the stock table to understand. Im not on my laptop right now but if you have questions.
Trying to get this table correct youll cause and fix torque errors. Like I said lol its almost not worth the time unless it's your car or you have the car with no deadline.
Also looking for this throttle body Data, The situation is a little different as it is an Edelbrock Eforce on a gen 1. The blower is being spun at the max RPM of the 2.3 eaton rotor set with crank and charger pulley changes. I think the stock throttle is actually hurting it here, So I am hoping the 90 mm with a little blower snout porting will be enough to get me over the 700 rwhp mark. We were at 666 rwhp before 10% over crank pulley with stock throttle body.
