Results 1 to 9 of 9
Thread: 5.9 Magnum Gas Dodge Ram Tuning and Tire Size Change
    Mar 2021
    looking for some tune files for dodge magnum 5.9 360ci gas engine
    Tuner in Training 14HemiRam's Avatar
    May 2020
    Oklahoma City, OK
    21
    Have you come across any? Anyway you could share you stock file my son has a 96 Ram 360 and was wanting to check out what all can be tuned. Thanks
    Jun 2021
    Savannah, Ga
    15
    i have a 2001 Durango 5.9 file 2001 Durango RT David.hpt
    Tuner in Training jimmyZJ's Avatar
    Apr 2021
    14
    I'm tuning zj 5.9 for E85
    98 ZJ 5.9 and Dodge Ram 5.9 have very different calibration file, fuel & timing
    Jan 2022
    6
    have you found a tune yet?
    Quote Originally Posted by rmcleod View Post
    im trying to find a way possible to adjust tire size / speedo with jtec+. doesn't seem to be a way in HPT
    2000 Dakota R/T
    gt45
    42lb
    honda map
    10psi
    Jan 2022
    9
    Here's a 5.9 magnum base tune
    01ram59.hpt
    I'm also looking for a way to calibrate the speedo. I tried the "controls and special functions" in VCM scanner but it's just blank. Seems the answer is it's not supported on our vehicles. What are our options for changing speedo for new tire size?
    Aug 2021
    Akron, OH
    34
    Jtec/+ tire size calibration is set in the ABS module. You need a higher end scanner to set. HP tuner only talks to the PCM on Jtec cars. I have a snapon solus edge that does it.
    Quote Originally Posted by putts000 View Post
    damn.
    2000 Dakota R/T
    gt45
    42lb
    honda map
    10psi
