Originally Posted by
2016SSlt1
I do have a wideband. Fueling is pretty much spot on. Its listed in the channel list as WB EQ Ratio 1. From my understanding the Desired Fuel Pressure should match Fuel pressure, which it does, unless this information is incorrect. According to the FSCM table Max desired pressure my pressure should drop to 50 Psi like it is doing in the log. My concern was that the Duty Cycle goes to 100%, which it would not do before the cam and recent tuning.
I am assuming the additional airflow increases the fuel flow, which now is commanding more open loop pump DC. I would just like to confirm that this is in fact true and I am safe with my stock pump.
