Originally Posted by
Russ K
I'm not sure what questions are being asked or answered. As these pics show, the VE tables use tps as the load axis, except for the idle VE table (map). And if the VE table needs to be higher than 100%, you need to enter that % into the VE offset table.
I'm still not getting what a 2bar set up will do?
Closed loop will be enabled (STFT) at any tps% below the pe tps% enable. Since there is no open loop table on the 2.2 engine yet, the commanded open loop AFR will be all over the place when not in pe. This is why only the wot (pe) areas of the VE table can be set in open loop. The part throttle (none pe) areas of the VE table will have to be set up in closed loop by logging the LTFT's. Also 14.7 psi is 1 bar, not 2, vacuum is anything lower then 14.7 psi (sea level)
Russ Kemp
