2008 Chrysler 300 5.7
Got a tune to increase shift firmness and now limp mode. Codes p0371-5
What are the gear ratios for a nag1 and what should I check for to fix this issue?
Also, I see there’s 3 tables for upshift, normal, performance and winter. How would we select either on the fly? Could I just tune the normal as I would the performance and call it George?
Give me your email and I’ll send them
By the prickle of my thumb something wicked this way comes!2008 Chrysler 300c! 2013 heads/220/230 comp cam/LTheaders/FTI 2600 stall converter.
Lmk i need this fix too
my fix was gear ratio and tire size
still stuck
did you ever change your gears in the rear or tire size? i didnt change ant of those, just a tune for firmer shifts and now im in limp mode
