01 Z28 6.0 243 Heads LS6 Intake 230/236 Isky Nitrous Cam TH400 4500 Stall E85 Siemens 80# 78/75 tune Still 2 Bar at 6# to start SD Tune
Does anyone have a base tune I can peek at for reference to above?
Thanks!
Thanks!
2000 Camaro SS 408 TH400
2012 Subaru WRX STI
2013 Camaro SS
2001 Corvette Z06
Here's one that I did a few months ago for a 2001 Silverado 5.3L with the same 411 PCM that you have. It had two small turbos and some 75 lb/hr decaps.
2001 JOEL TWINSwith75injectorsbase.hpt
Thanks! stock 5.3 minus turbos and injectors?
2012 Subaru WRX STI
2013 Camaro SS
2001 Corvette Z06
Stock 5.3L, but had Sloppy Stage 2 cam and correct valvesprings.
Awesome thanks!. What kind of boost were you running and how did it turn out? Another question on the vehicle when I plug in it doesn't have the option to enable 2 bar in the OS how do I verify that it might have been applied previously? The car was running an SD Nitrous tune when purchased.
2012 Subaru WRX STI
2013 Camaro SS
2001 Corvette Z06
Click on the Calibration Details icon on the Editor toolbar and see what the current Operating System is. A custom OS may have already been applied.
If that's the case, you'd have to do a write entire to restore the original OS.
so when I was comparing your file you linked me to this I am understanding most but I don't know why he doesn't have an option in the OS to enable 2 bar. The car was previously tuned on nitrous and I don't have the original file. Here is his file with a few adjustments from yours.
Calibration details are blank it says OS 2020005
2012 Subaru WRX STI
2013 Camaro SS
2001 Corvette Z06
Yours already has a custom OS applied to it. Looks like an EFI Live OS. It has a separate fuel table for boost, and a separate spark modifier table for boost. It should work fine in your application, but it'll just be different than the one tune that I posted.
If you'd prefer to convert it to an HP Tuners based 2 bar OS, you'll just have to license a stock file and do a Write Entire, then start from scratch.
2012 Subaru WRX STI
2013 Camaro SS
2001 Corvette Z06
It will transition into the boost VE table when it exceeds 105 kPa. Your Primary VE table is set with some pretty large numbers at the 90-105 kPa range. You can review my tune for an idea of the values at 100 kPa...typically 90-100 is about right. Yours goes up to 131. I'd adjust that, then you can can focus on the boost table. It's zero'd out at this time.
Thank you that makes sense! How does this look?
2012 Subaru WRX STI
2013 Camaro SS
2001 Corvette Z06
Those numbers look more appropriate to start with.
Be sure to force it to SD mode by changing P0101, 102, and 103 to MIL on First Error.
Thank you
2012 Subaru WRX STI
2013 Camaro SS
2001 Corvette Z06
It won?t idle if I set the map parameters to 200 do I need to keep it at 100 since it has a boost table?
The MAP sensor Linear and Offset values are solely dictated by whatever MAP sensor you are running. Do you know the part number for your MAP sensor?
The map is a new sensor is from a 2005 cobalt ss PN# NTK MA0097
2012 Subaru WRX STI
2013 Camaro SS
2001 Corvette Z06
The MAP shown in the Cobalt tune file is the 5-pin TMAP, the 3-pin 2-bar sensor commonly used is actually the Cobalt SS baro sensor and is not in the tune file.
