Results 1 to 13 of 13
Thread: cold start issue with fish dual cp3 controller
    Advanced Tuner MAIDENCR's Avatar
    Sep 2018
    Quebec,canada
    208
    It start then stumble for couple second then come back to normal......when hot no issue....tried lot of dc start up change and didn't help...someone have an idea?
    cold start.hplhot start.hpl
    03 cummins,175% flux injectors,dual cp3,s467.7/83 1.00
    Nv5600 with valair triple disc clutch
    Jun 2018
    Albuquerque New Mexico
    467
    Your cold start data log dops to 2700psi possibly falling outside the minimum pressure required to actuate the injector where you hot data log doesn't. You're also making 15kpsi on startup then it appears to overcorrect this over shoot when cold where hot it doesn't. That's almost 3x above commanded pressure on both logs.
    Sep 2018
    Quebec,canada
    208
    Yup im at this conclusion too...but dont find how to "fix" it
    Jun 2018
    467
    Quote Originally Posted by MAIDENCR View Post
    It's in the PID loop control for your pressure control valve. Usually the derivative value will need to be lowered a bit, that's the error rate of change it'll target for it's final correction. Since it's over shooting it'll require reducing. check out this ivdeo https://www.youtube.com/watch?v=wkfE...channel=MATLAB to help visiualize it. Also Post your tune and ill see if i can find the appropriate table.
    thats a darn handy youtube
    2010 F-350 03 5.9/848ecm, built 5R110, 30% over sticks, 10mm pump, 64mm Stealth Turbo
    2008 F-350 03 5.9
    Fumminstuning.com
    Jun 2018
    467
    Btw there may be other tables at play here causing a worse reaction when cold, like adding something to the control loop. I don't tune dodges But there is no doubt that going from one pump to two will require some massaging of the control loop to get factory like desired results.
    Sep 2018
    Quebec,canada
    208
    Hum will look into that to see
    Sep 2018
    Quebec,canada
    208
    Quote Originally Posted by JaegerWrenching View Post
    look at regulator pid
    Jun 2018
    467
    post a tune file even your stock one so i can at least see all the tables available and not have to zoom in
    Sep 2018
    Quebec,canada
    208
    dual cp3 controller13.hptstock+code.hpt
    here is my tune and stock tune
    Sep 2018
    Quebec,canada
    208
    Issue fixed....controller didnt had power at start position and it would spike rail pressure during cranking
    Jun 2018
    467
    Did it also fix the dropping too low issue as well?
    Sep 2018
    Quebec,canada
    208
    Fixed everything
