Results 1 to 4 of 4
Thread: Logging HZ with pro link
    Feb 2019
    5
    Upgraded to pro link for the external inputs. My plan was to graph my cooler flow out of my Sonaflow, but as I'm reading the only analog inputs are supposed to be in voltage and I need to log HZ, specifically 0-400HZ. Sonnax has a chart for HZ to GPM conversion so if I could see it in HZ I can do the math. Any thoughts or input would be appreciated.
    7,595
    Arduino/Raspberry Pi.
    And while you are struggling through the process of writing your own code to make it work, get increasingly pissed off that Sonnax didn't make their product usable by normal humans by building-in a simple analog converter.
    7,595
    Feb 2019
    5
    thanks, I think the converter is probably the way to go if I can scale it back to 1v = 1gpm that would be easy to read. I'm new to external inputs so I was hoping there was a feature or work around that I didn't know about. Thanks. I'll update this thread if I get if figured out.
