I'm having some issues with my build that I want to try to sort out before I take it to another tuner. I have an ls3 based 434 in my Chevelle running off an 05 gto e40 ecu. The issues I have are surging when coming to a stop and hard starting while cold, I have to give it a lil gas or it'll die after starting. The car also seems a lil hesitant below 4000 rpms. Most of the issues came after the NW 102 tb. The car drove better with the factory 90 tb. I've also installed 60lb injectors today I have been using the factory 42lbs for over a year now.
Here are the mods done to the engine.
Re-sleeved ls2 block. 4.155 bore
11.7 dynamic compression
FIC 60lb injectors
241/250 .630/615 114 +3
280cc ls3 heads ported by advanced inductions
fast lsxhr intake
NW 102 TB
arh 2 inch headers
t56 magnum
I'll upload my tune, modified for the 60lb injectors, a log file, and a copy of the injector data if anyone wants to look it over for me to see if I made a mistake.
Quentin Lawrence 2005 GTO M6 434 LS3 heads inj 241-250-114 BIG MAF 102TB PG tune 60lb.hpt7_21.hplFIC630CC-60LBBOSCHEV14LSXHPT.xlsx
