Results 1 to 7 of 7
Thread: trouble getting a 1.4l cruze to run
    Jan 2021
    10
    no past history of car i am trying to just get it to run right before i mess with it im not muvh of a tuner trying his as a project to get it running i figured it needs to run right before i destroy it tuning swapped in a new used engine and it seams to be running lean can anyone give me any pointers ?
    thanks if anyone help cj
    7,629
    I don't like the look of that MAP trace, very regular spikes like that usually indicate a mechanical problem. Verify the basics - compression, no misfires, etc.
    Remove all the Bank 2 channels from the scanner, you have no bank 2 on an inline engine.
    Jan 2021
    10
    i am about to do the valve fix in the intake for the pvc, what would i look for mechanically to do with the map ? could that be the pvc valve in the intake?
    7,629
    I would start with a compression test.
    Jan 2021
    10
    idles on all 4 engine came from a car with no issues i drove the donor car,
    7,629
    Oh good, then it sounds like you have it all figured out.
    Jan 2021
    10
    tell me expert why would it loose compression going from one car to another in 1 day ? i dont have it figured out but its a waste of time to do a compression test if you dont want to help dont no need to be a prick
