Results 1 to 2 of 2
Thread: Hi-Flow Cats Error P014B
    Apr 2021
    MD
    51
    I'm getting an error P014B with hi-flow cats. https://www.engine-codes.com/p014b.html
    is this tune or hardware related to fix?
    13,559
    Usually a sensor or wiring issue.
    Swap the sensor side to side with bank 1 to see if the issue follows. Not sure if your vehicle will let you do that because of wire harness length. I'm used to GM vehicles where everything is basically the same length on the harness so it's very easy to test that.
