I'm getting an error P014B with hi-flow cats. https://www.engine-codes.com/p014b.html
is this tune or hardware related to fix?
Usually a sensor or wiring issue.
Swap the sensor side to side with bank 1 to see if the issue follows. Not sure if your vehicle will let you do that because of wire harness length. I'm used to GM vehicles where everything is basically the same length on the harness so it's very easy to test that.
