im working on a 2009 chevy silverado with a 5.3l and we just swapped in a 6.0 from a 2008 gm 2500 but we are having issues with it it will not rev up past 2000 rpm in all gears ( stock 4l60e). stock everything from filter to manifolds, variable cam has been wired up and the factory 5.3 pcm has been flashed with the data from the 6.0 now we tried adding supplementary fuel in the the intake and bam working fine, fuel pressure is at 58 psi and no intake leaks
5.3 6.0 swap tune.hpt
