Results 1 to 9 of 9
Thread: what are the limits for LT4 injector
    Good day guys,
    I would like to know what are the limits for LT4 injectors, Pules width & Injector duty cycle ?
    So I can have an Idea when I reach the limit of the injector.
    Thanks you,
    Advanced Tuner Ghostnotes's Avatar
    Feb 2012
    Houston, TX
    471
    Not to hijack but speaking of limits as well, what's a ballpark on horsepower limits if swapping out your LT1's?
    I always tune VVE....
    2016 C7 M7 Z51
    Callies ultra billet crank
    Callies ultra billet rods
    Diamond pistons
    Jhonson high speed lifters
    Ported and polished headwork
    Custom cam
    YSi-V7
    Jan 2016
    329
    What fuel are you using? What lambda are you targeting? Is the engine stock? Does it have an upgraded cam?
    Quote Originally Posted by cadillactech View Post
    Pump gas, Targeting around 12 AFR ( 0.80 to 0.85 lambda ), everything is stock
    2017 Chevy Silverado Full Bolt-ons, Whipple SC, Meth injection
    ONWER OF DYNO PERFORMANCE IN DUBAI
    https://www.instagram.com/dynoperf/?...YmMyMTA2M2Y%3D
    Nov 2009
    All Around
    3,149
    lets just say your inject PW should past 6ms
    Jan 2016
    329
    Quote Originally Posted by SultanHassanMasTuning View Post
    Ya, anything over 6ms and you are out of fuel.
    You say stock everything, is this an LT4 engine?
    Yes stock LT4 engine on CTS-V
    Dec 2008
    on the Dyno
    1,825
    It'll be pump limited before injector limited. Pressure will drop which will result in injector maxing out due to trying to compensate. A camshaft with proper fuel lobe will stretch the pump out quite a bit further which in turn will stretch out how far the injectors will go.
    FWIW rail pressure and injector timing are your friend!
    Located in Central Kentucky
    ShorTuning
    Jan 2016
    329
    Quote Originally Posted by LSxpwrdZ View Post
    Completely right! Also, making sure the low side is feeding that high side pump enough fuel is important too, always watch the low side pressure while logging!
