So I had just installed my LS2 style valley pan and catch can and drove my 06 trailblazer the day before. Everything went great after installing new coil packs, Moroso wires, new NGK plugs, flow matched and refurbished stock injectors and new valve cover seals as part of an earlier DOD delete where I installed a Bryan Tooley stage 2 V2 truck cam and replaced a bent rod.
I thought everything was great. The next morning it started right up better than ever before. I gave it a little gas pedal and it stalled. Then it would not start. I do not have spark on the only cylinder I tested. Fuel pressure at the rail is 58 lbs. static. I can smell fuel when it cranks. The spark plug looks fuel washed and hyper clean, no carbon whatsoever, but it is new. I will disconnect fuel pump relay for further testing.
Any ideas? I am currently learning HP Tuners software, so I am unsure what to do. FYI: I have an AEM wide band gauge installed, but it is not functioning correctly in my scanner yet, only my gauge face indicates what my AFR is. Thanks in advance.
