hi gang,
quick question.
during the WOT shift (a4) does the TPS close for a split second or what ever?
2002 3.8 fbody.
thanks
hi gang,
quick question.
2002 3.8 fbody.
thanks
The spark timing will retard during the shift (upshift torque reduction). Never seen the throttle close on a wot shift.
Russ Kemp
i've seen it go as low as 45% tps on a stock tune during WOTOriginally Posted by Russ K
see the attached log of a friend's stock tune. you can see at around the 3600 mark (is that a counter of some sort at the bottom?) the TPS backs off quite a bit.
if you get rid of torque management, it does not do this to you.
