Results 1 to 6 of 6
Thread: Straight pipe, tune?
    May 2021
    Pittsburg California
    35
    Installed a straight pipe exhaust on my 07 set 8 charger. I notice a huge power loss down low, will a tune help correct this? or do I have no choice but to put mufflers back on? Any help would be much appreciated!
    Jun 2021
    Ireland
    16
    Did you go straight pipe before the cats? I went straight pipe after cats and no power loss or gains. Just more sound and it sounds amazing.
    Tuner in Training JohnJeep's Avatar
    Jul 2021
    Guelph
    13
    A tune will help a little bit but straight pipes will move power to the upper end of the RPM band.
    04 Intrepid 2.7-Stock
    98 XJ 2dr 5spd-stock
    88 XJ 2dr 5spd-boosted 4.7 stroker
    Oct 2005
    baton rouge la
    411
    Mufflers or lack thereof will not make a noticeable power difference either way. If you straight piped before the cats its likely you will feel a change in power band based on rpm. Ie loss of power down low but a gain in upper rpm
    Advanced Tuner outlaw_50's Avatar
    Nov 2020
    United Arab Emirates, AlAin
    204
    Check your fuel trims, then adjust accordingly
    Xstages Motorsport
    Tuning inquiries:
    ECU, TCU, CPC Online Tuning
    Whatsapp: +971503383340
    Email: [email protected]
    Insta: @xstages.motorsport
    www.xstages.com
    May 2018
    Germany
    586
    Modern engines are not for straight piping.
    exspecially the Hemi uses the cam for egr operation.
    So you have to change a lot of hard and software to get it running.
    Even the O2?s are made for catalyc operations. the flow rate and timing in regulation is different.
    Use some back pressure to make it easier.
