Im tuning a 2016 Ford Fusion AWD 2.0T DI
I was able to increase the boost from roughly 130kpa stock to 180kpa+ but the throttle is closing. Can anyone help?
I have included the stock file, tuned file, and log of throttle closing.
Thank you.
Thank you.
It's likely due to a torque limit somewhere. I can't look at the logs currently, but are you logging all the torque limit sources?
Owner/Tuner@Evolution Automotive Performance
Lincoln, Ne
if you want the throttle open while WOT, you should log "throttle position, effective throttle area, and ETC Vacuum" then you will find how to tune the throttle table.
Just give you a quick example as bellow
it will solve your problem on throttle opening
