Hi,
I have a 01 gt here with a 03 cobra swap in it, ECU and Harness swapped with the engine. Mods are:
Accurfab TB 1696 cfm
Deka 80lbs injectors
Bbk off road x pipe
Borla catback
2.76 supercharger pulley
Yukon 31 spline rear diff axles dura grip differential
Fore Performance dual pump set up with fpr @ 40psi and a hob switch for second pump
Car Idles on the rich side no matter what I do with Injector Scaling or Maf scaling. After a while STFT starts to knife step up to +99% and floods the motor with no change to fuel pressure, Engine load, O2 voltage, Air load or Maf airflow count.
I've done a few legit cobras on HPT no problems before, but this one is being a gremlin. If anything is wrong tune wise please let me know
