Originally Posted by
01SLPSSM6
So I did some research and found that according to Nick Williams himself, the Nw 103mm throttle body does not need the etc scalar changed on an LT1 application because it flows about the same amount of air to about 15% throttle. Obviously this is an LS application, but it may be the same for an Ls too. I would try the stock etc scalar and add some airflow to your minimum airflow table. Is your idle spark at your commanded idle spark? Is it having to add idle spark? I won?t be near a computer until tomorrow so I can?t check. Once you get your min airflow where it needs to be, you can adjust throttle follower torque.
