Results 1 to 7 of 7
Thread: Question on tuning MAF only
    Aug 2016
    SE WI
    87
    Not Gen 5 specific but I have a question I hope someone can answer.
    I'm running MAF only tune on E10. I used a WB to achieve .84 Lambdaggested for safe power. Question I had is there a calculation that you could use to tweak MAF table to change Lambda from say .84 to .86 or richer without having to reinstall WB?
    Jan 2016
    329
    Quote Originally Posted by DCZ View Post
    I'm running MAF only tune on E10. I used a WB to achieve .84 EQ as suggested for safe power. Question I had is there a calculation that you could use to tweak MAF table to change EQ from say .84 to .86 or richer without having to reinstall WB?
    Your MAF table characterizes the MAF transfer function. If it is correctly measuring the airflow entering the engine(you did calibrate during steady state conditions?) then your EQ ratio can be changed to anything you want because the air flow measurement is correct, your fuel injectors are characterized correctly(if they are stock) and the EQ ratio is just a target table.
    Aug 2016
    SE WI
    87
    should have used Lambda not EQ in original post..
    Yes, did the steady state MAF up to point of going OL.. I then purchased a WB to achieve a Lambda of .84 in OL.. I might ha
    ve this wrong but 02 sensors will keep maf @ lambda 1.0. Assuming no need to change CL portion of MAF table, wouldn't I be adding or reducing values to MAF scale to achieve desired Lambda desired in OL?
    I thought there might be a simple calc move Lambda from .84 to .82 or any other value by using a formula..
    Jan 2016
    329
    The MAF reads airflow not lambda or eq ratio or AFR.
    If your airflow model is correct(MAF) and your injector model is correct then all you need to do is change your target(lambda, or eq ratio or AFR) and it should hit your target. If it doesn't then your airflow model or your injector model or both are wrong.
    Aug 2016
    SE WI
    87
    So, even in MAF only tune, the EQ table is still used to determine requested EQ or Lambda or AFR?
    13,565
    Yeah. Doesn't matter if it's speed density or MAF tuned. The EQ ratio in PE will determine what the requested AFR/Lambda.
    Aug 2016
    SE WI
    87
    Thanks for the help and clarification!!
