Results 1 to 7 of 7
Thread: PATS Disable
    Mar 2011
    Ripley, MS
    1,865
    PATS Disable
    Does HP Tuners allow us to disable PATS on some of the earlier Fords? I've got a customer with a 2002 Mustang that has PATS issues on occasion. I'd like to disable it if possible.
    TIA!
    Jan 2021
    24
    Get FORScan... its free (the premium version is 30 worst case) and an obd dongle... its basically what the dealerships use, and you can reprogram/disable PATS with that among many other functions.
    Mar 2011
    Ripley, MS
    1,865
    Thank you
    Advanced Tuner Gimpster's Avatar
    Sep 2009
    Palm Bay, FL / Austin, TX
    445
    To answer your question: Yes, HPT can disable PATS... I have with my car since it had failed. But you already got good advice, don't blow credits on a 99-04 unless you have already or are doing other tuning.
    Mar 2010
    New Orleans, LA
    630
    forscan doesnt let you disable pats only reprogram it
    Oct 2016
    Poland
    1,750
    ForScan will not delete PATS. HPT will tip a PATS switch under SYSTEM tab which is just a half of entire PATS system.
    Other half is located in another part of memory which neither ForScan nor HPT can read.
    You can pull that extra piece of memory with few other tools and work you way trough - this will be digging in binary manually so nothing for "mere mortals"...
    Mar 2010
    New Orleans, LA
    630
    thats not the case on the older ecus as the pats switch will disable it
